Question Idle BSOD - Kernel Power 41 with Vol mgr 162/161
Sep 8, 2022
4
Hey so this is on a semi fresh install(About 2 weeks ago) that I keep getting these crashes whenever I just leave it to idle during the day,
I don't get to catch the blue screens but I'll comeback to a log on screen and know that it's crashed by looking at event viewer.
- <Event xmlns=" ">
- <System>
<Provider Name="volmgr" />
<EventID Qualifiers="4">162</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2022-09-08T17:24:14.1208284Z" />
<EventRecordID>16526</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="316" />
<Channel>System</Channel>
<Computer>Vince-Desktop</Computer>
<Security />
</System>
- <EventData>
<Data>\Device\HarddiskVolume6</Data>
<Binary>000000000100000000000000A2000400FD4B00000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
And immediately this one:
- <Event xmlns=" ">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>8</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2022-09-08T17:24:14.3027959Z" />
<EventRecordID>16529</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">307</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x501</Data>
<Data Name="BugcheckParameter3">0x500</Data>
<Data Name="BugcheckParameter4">0xfffff8074a105330</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
</EventData>
</Event>
There's also hyperVisor errors but I have it disabled as I kept getting DPC watchdog violations or hypervisor crashes multiple times a day so I just leave it off and that's what the error states
"Hypervisor launch failed; Either SVM not present or not enabled in BIOS."
Full Specs:
Win 11 Pro x64
Mobo: Asrock X570 Phantom Gaming 4
CPU: Ryzen 5 3600
GPU: Asus Strix RTX 3070 Ti
RAM: Gskill Flare X F4-3200C16D-16GFX
Hard Drives: Boot - Samsung SSD 860 EVO 500GB 500.1 GB(90% Life)
Storage Drives - Samsung SSD 860 EVO 1TB 1000.2 GB(98% Life)
KINGSTON SH103S3120G 120.0 GB(88% Life)
ST500DM002-1BD142 500.1 GB(Seagate 7200RPM)(Good Smart Status)
I can't figure out if its the RAM or the two older drives(Kingston and Seagate), I plan to replace them int he future but after some cursory searches I've found that the volmgr code is linked to RAM? Or is it not in this issue.
Any help is appreciated.
- <Event xmlns=" ">
- <System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Correlation />
<Security />
</System>
- <EventData>
</EventData>
</Event>
- <Event xmlns=" ">
- <System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
- <EventData>
</EventData>
</Event>
Full Specs:
Win 11 Pro x64
CPU: Ryzen 5 3600
Try running userbenchmark.com and post a link to your results here if you can. It sounds like the ram is having a issue. And in most cases with windows 11 this error is created when xmp isn't enabled or using the wrong profile. Or docp for amd systems isn't enabled again causing ram issues
I should have said this in the initial post, I have enabled the XMP profile or this RAM, it crashes with or without it enabled and more if I enable SVM.
I have IOMMU enabled and tried disabling it but got the same errors as well. I leave it enabled because Ideally I plan to switch back to Linux once i resolve this hardware issue and figure out all my workflow replacements.
Userbench link
I am aware of the slight bottle neck on my 3070 with the R5 3600 and intend to deal with that by getting a more recent Ryzen.
Userbench link
You need to update the bios, the bios has several stability updates that correct a lot of crashing issues.
Does
Userbench link
The system crash at all 😛 n bios
I double checked and i'm running the latest version(4.30 according to asrock) and reflashed it after clearing Bios, waiting to see if I have any issue with SVM and IOMMU enabled.
