Archived from groups: alt.comp.hardware.overclocking (
More info?)
"jester_s1" wrote in part
"I am planning to OC the processor if I can get stable operation from it. I
see little reason not to take advantage of the free speed if I can do so at
no cost."
I am glad you are taking a 'wait and see attitude'. The fan speed is
certainly not near its maximum, so, without the operating system installed,
the 35 degrees C (95 F) CPU idle temperature seems reasonable.
As for overclocking; I wouldn't do it. No matter how stable overclocked
operation seems, office requirements really don't even demand stock speeds
from a Pentium 4 2.4C. I doubt any user would notice performance
differences between 2.4 GHz and 3.2 GHz. For office work, hard drive
performance and memory size can make more difference than the jump from 2.4
to 3.2 GHz. In a small office with no technical support staff any systems
should save the temperature safety margin for things like dust bunnies
clogging the heatsink and ventilation grilles rather than for overclocking.
It would be of little use if the overclocked CPU ran at a throttled down
speed because of dust degradation of the cooling system. Especially since
the user would likely
a. not realize the throttled down mode was active
b. not realize WHAT speed the CPU was running.
Finally, if you are using a website to post, you should be aware its Usenet
newsgroup posting is broken. Each of your replies shows (by indentation) as
a reply to your own initial message rather than the message you intend
response. In addition, there is no information from the message you reply
to, so the thread becomes hard to follow, and will be especially so when
viewed in Usenet archives (at Google.) Using your own newsgroup reader to
post (Microsoft Outlook Express or third-party news reader) as well as read
newsgroup messages would be helpful for you and others.
Phil Weldon, pweldonatmindjumpdotcom
For communication,
replace "at" with the 'at sign'
replace "mindjump" with "mindspring."
replace "dot" with "."
"jester_s1" <e_mayhan@hotmail-dot-com.no-spam.invalid> wrote in message
news:41f522f6$1_4@alt.athenanews.com...
> Thanks for the help, Phil.
> I am using the boxed Intel cooler. The fan was running around 2300 rpm
> when I checked the temp. I'll leave it alone until I get the OS
> installed and can monitor the temp under load.
> it. I see little reason not to take advantage of the free speed if I
> can do so at no cost.
