Idle Temps on i7800k
Sagemblack
My Build
In Win 805 infinity
i7 8700k (installed with Arctic silver 5)
Hero x Maximus
Corsair Hydro H115i
Corsair LPX Vengeance 16GB 3000mhz
GTX 1080 Strix
EVGA G2 850W
Samsung EVO 500GB
Samsung EVO 1TB
2 x 1TB mechanical drives
My issue is with the idle temps that i am getting, i have already disabled Asus multi core enhancement, and i can see that intel turbo is on as my clock speeds are around 4.7Ghz
But i idle around 40-50 degrees and when stress tested with Prime95 (i know this is now overkill) it reach 85 degrees
I just feel with water cooling this should be lower or do the new CPU just run hotter?
one image does does 32 degrees but this was only just after startup
See images.
https://ibb.co/dfF1aR
https://ibb.co/kySgaR
https://ibb.co/guvOpm
https://ibb.co/mCpSFR
80c is bit on the toasty side, but as long as it's not running at 80c 24/7 it shouldn't have any impact on the cpus lifetime.
You could also undervolt it which should drop the temp a bit.
Have you got enough thermal paste on? Does the cooler have proper contact to the heat spreader on the cpu? is the h115i at fault? Are the voltages on the cpu at stock?
Hi Barkants14, Yes i ensured i had enough on and the fitting is easy with this unit, nice and snug, as i said it is being increased by the intel turbo but this should not react so badly. i think i make need to adjust the orientation of the fans and radiator
Thank you for the info, this is what i was really after knowing, if these temps were normal for this CPU, i dont want to venture into deliding as warranty and brand new CPU.
As long as these are ok to run the system and getting to around 60 - 80 max is safe then i have no problem
