Hey guys, I think I have a bit of a problem. This is my first time building a PC and although I love it but im not exactly happy with my temps. Currently I am running 3 case fans and a Be Quiet Dark Rock 4 (NOT THE PRO) CPU cooler. I sit around 40-50 deg. C at idle and peak around 70-75 deg C. under load. I originally built the pc with the stock cooler but that thing kinda sucked so i got this be quiet. Although I am in love with it i still want my idle temps to be lower then they are.
I am running two fans in the front pulling air and one exhaust at the rear. I have two more fan mounting options on the top of the case for 2x 120mm fans. Would it be worth it to fill these spots with more exhaust fans? Would I benefit more from doing this? I understand my CPU runs hot but ideal temps would be 30 deg C. Idle.
Specs -
RTX 2060 Super Dual
Ryzen 2700x @ 3.7ghz ( base clock no factory OC )
Asus x470 prime Mobo
3x Corsair LL120 RGB Case Fans > 2x Intake 1x Exhaust
Fractal Design Meshify C Case
16GB Trident Z RGB NEO ram
650w Corsair Modular PSU
Specs -
RTX 2060 Super Dual
