G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I've spent ages trawling for an answer to this problem. I found a few
messages from people having the same problem, but no answer as yet! Any help
much appreciated:
Using XP Pro, SP2, I've got the standard HP Laserjet 4 driver installed. [I
tried updating it with the files from lj631.exe but it failed].
Problem is, that when I print from within IE, try as I might to change the
default margins from 0mm to something else, like 10mm, they always
immediately reset to zero which means that all my print outs from IE have
their edges cut off. It only works once if I do it via print preview.
The margins don't appear as config options in the main Printer preferences
pane. Is there a way to set the defaults to something other than 0mm?
I've tried changing them in the registry, but it doesn't get picked up by
IE.
Thanks very much!
Pascal
much appreciated:
IE.
Thanks very much!
Pascal
