IE Problem
souren1975
Hello,
OS: Windows 7
Problem: IE and Firefox not opening any web site after every restart.
Observation: 1. Net connection is OK as Avast get updated, Any messenger can open and also SKYPEE works fine.
2. After doing the below on dos prompt, it opening sites
netsh int ip reset reset.log
Enter
netsh winsock reset catalog
Enter
Restart.
Again after restart need to follow the dos command then restart to open site on Explorer and Firefox
Please anybody can help me out.
Many many thanks to everybody to have look on the problem
Rgards
Hi
I was told the procedure was
netsh int ip reset
Enter
restart PC
Enter
Restart PC .
and you have to run cmd as admin even if logged in as an admin account
that worked for me in a similar situation
regards
Mike Barnes
