If I get an OEM Hard Drive, what will I need?
storm slider
224
Hi,
Alright guys, I'm trying to find all the parts for my first build onto Canadacomputers.com. I have a store from them near by.
Anyways, I have a problem. I was originally gonna get a retail HDD from Amazon.ca, but I want to pick up all my parts at my local Canadacomputers store, but it doesn't have any retail HDDs, only OEM.
So now I am forced to get an OEM product. I am scared that my HDD will be defective because an HDD is one of the few parts that are most likely to be defective. Since it's going to be OEM, what are the parts I will need to fully use the HDD? Thanks.
shadow_city
202
What zinix said as well as screws. Your case should come with screws but if you do not have any then you will need some 6-32-5 screws, 2-4 for each hard drive, depending on your case.
You may not actually need any at all if your case is tool less.
