If i get another GTX 770 for SLI will my PSU have enough power to power it?
Aceadam251
So as you can see i want to buy another GTX 770 so i can use SLI however i have a 650W Gold Efficiency PSU. So i wanted to know if it could power it.
Specs:
CPU: i5 3670K @ 3.40Ghz
RAM: 12GB
MB: ASrock Z77 Extreme4
GPU: GTX 770
PSU: Corsair 650W Gold Efficiency
No I'm afraid the recommeded power supply for 770 sli is 850 watts.Check this out:http://www.realhardtechx.com/index_archivos/Page362.htm
you know you can just make it but defiantly not advisable, look for a 800W PSU for headroom, you will get a blue screen if you use that PSU, as the wattage output is not enough, it will work when you do minor tasks, but when you put some load on the rig, power supply won't take it.
