if i have 16gb ddr4 3200 will i have the same speed if i add another 16 ddr4 3200mhz
MadTech Gameplay
12
if i have 16gb ddr4 3200 will i have the same speed if i add another 16 ddr4 3200mhz becauase i want to buy team dark white rgb ram in 32gb but they dont make it in 32gb only 16gb so will i have mpre or same speed
If you put two sticks of 16Gb 3200Mhz into your system then you will have 32Gb of 3200Mhz of RAM in your computer. Adding more sticks of RAM into your computer will not increase the speed, only the capacity.
You will have the same speed, but 3200Mhz is very fast and you do not need anything faster than that.
Make sure that when you buy more RAM that it is from the same company, preferably the same model. It might not work if they are from different companies (ex Corsair 16Gb & Team Dark 16Gb).
I hope I answered youre question, good luck.
Maybe. RAM is sold in kits for a reason which is to ensure compatibility. Different kits can have completely different DRAM modules even if they are the same speed. Even different kits from the same company.
Ideally you want a matched set.
Next would be the same model number from the same brand. This will usually work.
Everything else? Maybe. There are no guarantees.
Do you really need 32GB?
Edit: Should add that an Intel system will have a better chance of different RAM working together. If it's a Ryzen system don't even try it.
