[SOLVED] If i have to upgrade my pc in future , which parts i need to upgrades? (not much expensive)
Jul 6, 2020
My current specifications:
Graphic Card : ZOTAC GeForce RTX 2060 (ZT-T20600H-10M)
CPU : AMD Ryzen 7 1700
Motherboard: MSI A320M PRO-VD/S (MS-7A36)
Ram: Carsair Vengeance LPX 8GB DDR4 2666 MHz (8GBx2=16GB)
PSU: Corsair VS550 550W Active PFC 80 Plus
Storage : 1) Kingston SSD A400 240GB
2) 2TB WD Hard Disk
Case : antec nx200
& 4 x Antec spark 120mm RGB Fans
Monitor: AOC C24G1, 144Hz 23.6inch Curved Gaming monitor
Mouse : Logitech G502 Hero
Keyboard: Logitech G Prodigy G213 RGB Gaming Keyboard
i'm using this pc for net browsing, gaming, not professional gaming ,office work, home use.etc.
Jul 6, 2020
2) 2TB WD Hard Disk
Case : antec nx200
If you are upgrading in the near future
  1. Ryzen 4th gen CPU
  2. A better motherboard, i would suggest you go with a x670 motherboard
  3. If you are gaming at 1080p 144hz, your RTX 2060 will probably be fine
  4. Definitely a better power supply (you can use https://outervision.com/power-supply-calculator to calculate the right wattage of PSU to get )
  5. Ryzen loves fast ram, 2x8GB 3600 CL16 Kit will boost your performance significantly.
Reactions: AniketW99
2) 2TB WD Hard Disk
Case : antec nx200
  1. In first order, motherboard, that one is no good for any better CPU, can't overclock and is lousy at handling faster RAM and will never be able to host next gen (4000) Ryzen.
  2. CPU but #1 is a problem.
  3. GPU but would probably also need stronger PSU, depending on GPU.
Jul 6, 2020
2) 2TB WD Hard Disk
Case : antec nx200
