If I put more wireless cards into my MOBO will it make my connection better/faster?
crowlwi
18
I currently have 1 Gigabyte WIreless Adapter in my PC, but have slots for two more, if I put in more will it boost my internet speeds?
Build:
Gigabyte - GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter
Tomahawk B350m
Ryzen 3 2200G
8 sad little gigs of Viper 2400 ram
Nvidia GTX 1060
Thermaltake 500w
You can't bond wifi links the same way you can an Ethernet connection. In fact any wireless card that mentions using MIMO is effectively already a bonded wifi signal IIRC.
Like Snipergod87 says, your choices are spend more on a newer faster wifi card or get a wired connection.
