[SOLVED] If i use a 60hz monitor power cable for a 240hz monitor will it lower the hz?
john324324
BANNED
Jul 20, 2021
25
I am using the acer xf 250q 240hz monitor and i have a 60hz monitor power cable if i use the 60hz monitor power cable for my 240hz monitor will it decrees my hz will it still show 240hz?
Gamefreaknet
Great
Mar 29, 2022
125
no. the monitor may be able to process 240hz refresh however since the cable will be limited to a maximum capacity of sending through 60hz at once the monitor will cap at 60hz as that will be the max it be will receiving from the cable.
Ertrius
107
No, the power cable will not lower your refresh rate. The 60Hz. frequency from your wall outlet is totally different and unrelated, from your monitors refresh rate.
