If I use a dvi to hdmi adapter will I get audio when I plug in headphones to my pc jack?
Yes, the audio jack on your PC will still work.
If you mean the audio jack on your computer then yes it will work, the display connection doesn't affect that.
If you mean the audio jack on your monitor, it will work if you go from DVI computer to HDMI display, it will not work if you go from HDMI computer to DVI display.
