If my case's fans connect to peripheral cables and 3 pin cables do I need to connect to both?
bfr43267
31
Also my motherboard does not have enough 4 pin fan ports so can I just use a peripheral cable to connect the rest?
The main downside I found in connecting fans to the peripheral cables instead of the motherboard is you lose the ability to have your motherboard in control of the fan. That's assuming your motherboard has controls for fans in the first place. That's why some people will invest in fan controllers. You can hook your fans to it, then control the fans from there, without involving your motherboard at all.
