Hello,
I have a lenovo k450 which I bought a few months ago and It brought a Geforce GT 635 2GB and I'm planning to upgrade it. I ordered a GTX 750ti 2GB and I'm about to order a new PSU and my question is.. would my motherboard be capable to work with these 2 new components. The motherboard is a lenovo motherboard and I couldn't find that much information about it and I have no clue on where else to look.. I downloaded CPU Z and took a screenshot of the motherboard info part:
Motherboard CPU Z: http://gyazo.com/3dfa9e6c5dae7ec16fb96bc89d97a202
Lenovo k450: http://www.techrecoveryllc.com/lenovo-k450-i5-4440-3-10ghz-quad-8gb-1tb-dvdrw-windows-8-64-bit-gt635/
Here's the GPU I bought: http://www.amazon.com/GeForce-750Ti-GDDR5-Graphics-GTX750TI-OC-2GD5/dp/B00IB9P1KG/ref=sr_1_2?ie=UTF8&qid=1420259573&sr=8-2&keywords=gtx+750ti
Here's the PSU that I will order: http://www.amazon.com/gp/product/B00H33SFJU/ref=s9_simh_gw_p147_d0_i4?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=desktop-1&pf_rd_r=066X2602ZF6T6PHN2Z2Y&pf_rd_t=36701&pf_rd_p=1970559082&pf_rd_i=desktop
Would gladly appreciate it If you reply!
