IGD Multi-Monitor Disabled/Enabled ?
Mitko2624
23
Hello guys,does this option have to be enabled in the bios for better graphics (IGD Multi-Monitor) ,because I have gtx 960,will that option will reduce the power of my videocard or CPU when it is Enabled?Which option is better Disabled or Enabled?
It should not affect the performance of your GTX 960. The IGP multi monitor just allows you to add another monitor using your motherboard display ports and integrated graphics if your cpu support it.
Suztera is exactly right, its just enabling your on-cpu graphics to use for a secondary monitor.
