the driver was the intel graphics driver
but the Bug Check 0x50: PAGE_FAULT_IN_NONPAGED_AREA
looks like the driver was writing to valid address (rather than a clearly bad address)
I would look for overheating, maybe a stopped fan. (I assumed you already updated the device driver)
I would test for hardware memory problems by booting and running memtest86
The problem can also happen when another device driver corrupts other devices memory areas.
in that case most people would go to the vendors website, update the BIOS, and various drivers for their machine and run and see if the problem goes away.
if you do these and get another bugcheck, you might copy the actual memory .dmp file to a server and post a link here so someone can take a quick look with a windows debugger.
