IGP for I5 and power drain
flashstar
32
Hi!, I will be using the IGP hd4600 on my i5 4570, , I just wonder If using the IGP the CPU will use more power and thus generate more heat and maybe require extra cooling tan if I used a dedicated graphic card
nothing to be alarmed about....just a couple of degrees
you wont be able to make that out, of course it is always better to have an after market cpu cooler, stock cpu cooler sucks
should work fine but the paste on the stock cooler isnt the best if you find your temps are hitting higher then you like get mx4 paste after cleaning of the old paste of cpu and cooler
