I'm a little confused on this case and details, thanks for your help!
marquette eagles
22
I'm building my first comp, so my knowledge is fairly limited and may be asking basic questions. I was thinking of getting the DEEPCOOL KENDOMEN ATX Mid Tower, for one its a pretty good deal, and comes with 5 preinstalled fans. http://www.newegg.com/Product/Product.aspx?Item=N82E16811853012
What I'm confused about is the molex power connectors, some reviews have been complaining about those. I don't even know why they are bad etc. And would I plug all 5 fans into my MOBO?
Also if you could recommend a good CPU temp monitor without ads and crap that would be great. Thanks a lot!!
i have no hesitation recommending that fan controller
and yes theres a ton of cases in that price bracket too many for me to look through
perhaps some one in the usa will know which are the best cases at that price point
Is it preferred to plug them into the motherboard? And on realtemps site they don't mention windows 10 compatibility?
i prefer to plug them into the motherboard so can control the speed of them
and i am using windows 10 64bit and realtemp runs fine only thing is you have to launch it manually when you start the pc or schedule it as a task if you want it to run itself
that doesnt bother me main thing is i find it accurate--free--and no ads etc at all
Any recommendations for a fan controller, I'm seeing a ton and don't really know what to look for. Im skeptical about the touchscreen ones being only $5 more than a knob one..
I was looking at that controller as an option seems like a good one, and after what you guys have said ill look at other cases. There are plenty other ones
