Question I'm at loss, cpu cooler clearance for my ram.
ardhika
22
Hello there, I'm planning to upgrade to 5800x3D in a week but I'm still struggling to find the best cpu cooler that suits to my rig, currently I'm using G.Skill Trident Z RGB in a second and fourth slot. I received mixed opinions as to whether Deepcool AK620 will fit or not. I have several other choices such Noctua NH-U12S Redux and Arctic Freezer 34 esport Duo but I'm not sure whether they're adequate for the cpu I'm going to use.
*I dont have thermalright peerless assassin sold in my country, or I can go with bequiet dark rock pro 4 as well.
According to TPU, there's clearance for dimms UP TO 43mm tall. For dimms past that, the front fan should be raised up for each millimeter, but that increases the total height of the cooler, so check your case clearance spec.
That ram kit is 44mm tall, so the front fan needs to be raised a millimeter or 2.
Reactions: ardhika
Hello, forgot to mention Im using lian li lancool ii mesh and from official website i got this info: CPU Clearance176mm
Is that what you mean? Do you think it will fit?
