I'm building a computer and want to know if my build i'm going to try will work.
Schl0ngGoblin
4
So on hand right now all i have is my CPU which is a Intel i5 4460. I will leave links for the parts i'm planning on buying so you can go there directly because i'm sure you don't know the parts by heart.
extra info : My budget is a little bit under $400...
MOBO - https://www.newegg.com/Product/Product.aspx?Item=9SIA1N83UN2409&ignorebbr=1
GPU - https://www.amazon.com/MSI-GAMING-GTX-1060-6G/dp/B01IEKYD5U/ref=pd_lpo_147_bs_t_2?_encoding=UTF8&psc=1&refRID=4VC81G8C1R7WPPNDKD65
PSU - https://www.newegg.com/Product/Product.aspx?Item=9SIA2F84BC9867&ignorebbr=1
(+thermal paste and some extra case fans)
I don't know much but from what i do know about computers i think this should work? I'm just nervous since I've never built anything like this before. Any comments or recommendations would be GREATLY appreciated.
Thank you
