http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128716
This one is pretty good if you don't mind the extra cost. It will allow overclocking and since it has the Z97 chipset, you will have support for the next generation of Intel CPU's if you decide to upgrade in the future. Plus, if you save and get the 770 instead of 780 as recommended earlier for 1080p gaming, you can use the money you saved for this motherboard.
