[SOLVED] I'm building a low spec gaming machine for my dad need help on specs
Jan 6, 2022
6
i need some advise on the components i have a spare r9 270 its very low end in this day and age but that is what i need to build around this is the Routh draft:
CPU: Ryzen 3 3100
ram : corsair vengeance LPX 16gb
motherboard: ASUS TUF B450-PLUS 2
PSU: EVGA 500 GD 80+ gold 500w
ASUS PRIME B560M-A $94.99
https://www.amazon.com/Intel-i5-10400F-Desktop-Processor-Graphics/dp/B086MHSTWN/Intel
Core I5-10400F $154.77
https://www.amazon.com/DEEPCOOL-GAMMAXX-400-Blue-Compatible/dp/B00JQ2YDCY/
DEEPCOOL GAMMAXX 400 CPU Cooler $19.99
Team T-FORCE VULCAN Z DDR4 3200 16GB (2x8GB) CL16 $59.99
Total: $329
Total: $329
im looking at your list Why_me thank you
Same board as up above but for cheaper.
geofelt
What case are you considering?
You should also use plan on a ssd of some size and type. It makes a lot of difference in everyday use.
I would consider using a i3-10100F for gaming. They sell for about $95.
It is a quick processor. I have built a few with them.
The stock cooler works perfectly well.
Here is a review:
https://www.techpowerup.com/review/intel-core-i3-10100/15.html
Any lga1200 motherboard will do. They sell for <$100.
EVGA power supplies have good and not so good models.
One thing to not go cheap on is the psu.
Buy a quality psu now and it will serve for a long time and can handle a future graphics upgrade.
Here is a Seasonic GX550 unit with a 10 year warranty:
https://www.newegg.com/seasonic-focus-plus-550-gold-ssr-550fx-550w/p/N82E16817151189
