Hey guys in building a new pc with those components
Cpu:Fx 6300 six core 3.5ghz
Mobo : Gigabyte GA78LMT S2
RAM: HyperX Fury blue 4GB 1333mhz(2 of them so 8GB total)
SSD: Crucial BX100 250 th
My question is whether are those compatible with eachother.I heard that you should upgrade your bios in order to support AM3+ cpus on this motherboard is it true and if it is then can you recommend me an Mobo that can support this Processor without updating bios for around 50-60 dollars max?what is the minimum psu wattage required to support my build? Also keep in mind that I already have my Gpu (Asus Radeon HD 5450
SILENT 2GB DDR3 PCIe 2.0) and my case and bluray.Thanks for your time
