I'm building my first pc and I need help with determining the compatibility of some parts.
DefenderII
11
Are these parts compatible?
-CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply New 4th Gen CPU Certified Haswell Ready
-ASUS Sabertooth X79 TUF Motherboard - ATX, Socket R (LGA2011), Intel X79 Express, 1866MHz DDR3, SATA 6.0 Gb/s, RAID, 8-CH Audio, Gigabit LAN, USB 3.0, PCI-Express 3.0, CrossFireX/SLI
-Patriot Viper 3 PV332G186C0QKRD 32GB Desktop Memory Module Quad Kit - DDR3, 4x8GB, 1866MHz, CL10, PC3-15000, 1.5V, XMP Ready
-Zalman Dual Fan CPU Cooler - Compatible with Multiple Intel/AMD Sockets, 120/140mm Fan, Long Life Bearing, 1000/1400 RPM, PWM Control, (CNPS9900MAX D/F)
-NZXT Phantom Enthusiast Full Tower - 5 x 5.25" Drive Bays, 7 x 3.5" Drive Bays, 7 x Exp Slots, 2 x USB Ports, 2 x Audio Ports, 1 x eSATA Port, Black - PHAN-001BK
-Samsung Electronics 840 EVO-Series 1TB 2.5-Inch SATA III Single Unit Version Internal Solid State Drive MZ-7TE1T0BW
-ASUS GeForce GTX TITAN Video Card - 6GB GDDR5, PCI-Express 3.0 (x16), 1x Dual-Link DVI-D, 1x Dual-Link DVI-I, 1x DisplayPort, 1x HDMI, DirectX 11.1, Overclocked, Dual-Slot, Fan, - GTXTITAN-6GD5
-Intel Core i7-3930K Hexa-Core Processor 3.2 Ghz 12 MB Cache LGA 2011 - BX80619I73930K
Also, what is Sandy Bridge-E? Is there a difference between these two CPUs?
-http://www.amazon.com/Intel-i7-3930K-Hexa-Core-Processor-Cache/dp/B00603QXPM
-http://www.newegg.com/Product/Product.aspx?Item=N82E16819116492
Mazooni is right.
Out of curiosity, what is the purpose of the build? The titan has been beaten by cheaper cards in gaming and a professional workstation card would be better fitting for most workstations.
I've become a bit concerned after reading this: http://www.newegg.com/Product/SingleProductReview.aspx?reviewid=3312598
The RAM that I'll be getting uses 1866MHz and 1.5V. Will this cause any problems?
I'm going to be using it for making 3D models and animations in a program called Blender. I've done a bit of research and I found that the Titan is one of the best cards for handling large texture maps, large scenes, and animations.
Sounds like a smart choice then, the pricey titan is kind of a niche item now.
If only they made a 6gig 780 ti... /:
The motherboard is compatible.
The problem that you linked to earlier is the intel memory controller. Alot of people overclock it to 1866 and its fine. It just is if something does go wrong like what happened to the guy you linked, the warrenty has been voided by the overclock. He likely had an inferior board or something. You should be fine
So should I stick with this: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4355829
Or should I pick a different one?
