im building my first pc but dont know if everything is compatable and i need help
Oct 4, 2018
25
im planning on building my first pc and i want to ask if everything is compatable with eachtoher
https://www.amazon.de/Sharkoon-VG5-W-Schnellverschl%C3%BCsse-120-mm-LED-L%C3%BCfter-vorinstalliert/dp/B015J8R1FY/ref=sr_1_2?ie=UTF8&qid=1541690682&sr=8-2&keywords=computer+case
https://www.amazon.de/Intel-Core-i5-8600K-60GHz-Boxed/dp/B0759FKH8K/ref=sr_1_3?ie=UTF8&qid=1541691150&sr=8-3&keywords=intel+i5
https://www.amazon.de/B250-Plus-Mainboard-Kabylake-DDR4-Speicher-Schnittstelle/dp/B01MTYDZVY/ref=sr_1_4?s=computers&ie=UTF8&qid=1541690721&sr=1-4&keywords=motherboard
https://www.amazon.de/Corsair-Vengeance-3000MHz-Performance-Arbeitsspeicher/dp/B017NW5NZY/ref=sr_1_1?s=computers&ie=UTF8&qid=1541691602&sr=1-1&keywords=ram&th=1
https://www.amazon.de/Dual-GTX1060-O6G-GeForce-Grafikkarte-Speicher-Displayport/dp/B01IPFN7UQ/ref=sr_1_4?ie=UTF8&qid=1541692128&sr=8-4&keywords=1060
https://www.amazon.de/Thermaltake-Smart-RGB-700W-PC-Netzteil/dp/B0744P7VHW/ref=sr_1_2?ie=UTF8&qid=1541692236&sr=8-2&keywords=power+supply
https://www.amazon.de/s/ref=nb_sb_ss_i_6_4?url=search-alias%3Daps&field-keywords=cpu+thermal+paste&sprefix=cpu+%2Caps%2C145&crid=3UOBM0FFAEW9F
https://www.amazon.de/Corsair-Hydro-Wasserk%C3%BChlung-Performance-schwarz/dp/B01FSMWFQG/ref=sr_1_4ie=UTF8&qid=1541692523&sr=8-4&keywords=cpu+water+cooler
https://www.amazon.de/Samsung-MZ-76E500B-EU-interne-schwarz/dp/B078WST5RK/ref=sr_1_1?s=computers&ie=UTF8&qid=1541698916&sr=1-1&keywords=ssd&th=1
thats all i planned
Oct 4, 2018
25
then what motherboards do support it?
Oct 4, 2018
25
is that everything that i need to change or is there something else too?
i just want to be sure until i buy it and figure out somethings wrong
I already answered you: H3xx/B3xx/Z3xx
Yes, getting a compatible motherboard will make the build fine. But not the best way of spending your budget. Can you answer my follow up questions?
major usage and budget?
Only amazon de?
Oct 4, 2018
25
well i will use it about 9 to 13 hours per day. im on a budget because i dont have that much money left. budget : 1000 euros
and im just looking at the things on amazon . de that i can see the price and how good but i will buy in an actual store, if needed i will order on amazon
9-13 hours gaming or productivity work? can you provide more details so that I can help with your choice of parts.
Oct 4, 2018
25
gaming or watching videos when waiting for friends, i will do some school work on it too.
i calculated everything and its about 926 euros if i buy from an actual store.
i changed the motherboard for a z370 p mother board
My take with better gpu:
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor (€157.99 @ Mindfactory)
Motherboard: Gigabyte - B450M DS3H Micro ATX AM4 Motherboard (€75.85 @ Amazon Deutschland)
Memory: Patriot - Viper 4 16 GB (2 x 8 GB) DDR4-3200 Memory (€135.89 @ Mindfactory)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive (€78.98 @ Amazon Deutschland)
Video Card: MSI - GeForce GTX 1070 Ti 8 GB DUKE Video Card (€340.31 @ Amazon Deutschland)
Case: Thermaltake - View 22 Tempered Glass Edition ATX Mid Tower Case (€58.90 @ Amazon Deutschland)
Power Supply: Corsair - Vengeance 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply (€62.07 @ Amazon Deutschland)
Total: €909.99
Generated by PCPartPicker 2018-11-09 15:39 CET+0100
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard (€113.89 @ Alternate)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory (€137.90 @ Amazon Deutschland)
Storage: Seagate - FireCuda 1 TB 2.5" 5400RPM Hybrid Internal Hard Drive (€54.90 @ Amazon Deutschland)
Video Card: EVGA - GeForce GTX 1060 6GB 6 GB GAMING Video Card (€249.00 @ Caseking)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case (€48.17 @ Amazon Deutschland)
Power Supply: SeaSonic - S12II 620 W 80+ Bronze Certified ATX Power Supply (€64.90 @ Amazon Deutschland)
Total: €826.75
Generated by PCPartPicker 2018-11-09 16:33 CET+0100
CPU: Intel - Core i5-8600K 3.6 GHz 6-Core Processor (€269.90 @ Caseking)
CPU Cooler: Thermaltake - Riing Silent 12 Pro Blue 53 CFM CPU Cooler (€44.90 @ Caseking)
Motherboard: Gigabyte - Z370 AORUS Ultra Gaming (rev. 1.0) ATX LGA1151 Motherboard (€194.40 @ Amazon Deutschland)
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3000 Memory (€158.89 @ Alternate)
Storage: Samsung - 970 Evo 500 GB M.2-2280 Solid State Drive (€120.90 @ Amazon Deutschland)
Video Card: Gigabyte - GeForce GTX 1060 6GB 6 GB AORUS Xtreme Edition Video Card ($249.99)
Case: Thermaltake - V200 Tempered Glass RGB Edition ATX Mid Tower Case (€79.90 @ Amazon Deutschland)
Power Supply: Thermaltake - Smart Pro RGB 650 W 80+ Bronze Certified Fully-Modular ATX Power Supply
Total: €868.89
Generated by PCPartPicker 2018-11-09 16:37 CET+0100
Oct 4, 2018
25
so should i do this one?
Oct 4, 2018
25
before i order them does the cpu come with a cooler or thermal paste or do i have to buy them seperatly?
Oct 4, 2018
25
ok thanks!
would everything fit if i used the case i picked or do i have to take the bigger one? i have limited desk space and cant fit alot of stuff on it
and what drivers do i need to install?
