im changing my ram i need some help.
hitman24
193
iw as going to get this ram
http://www.newegg.com/product/product.aspx?item=N82E16820231098
and this is the motherboard
http://shop4.outpost.com/product/5372008#detailed
but anyway since some stuff came up i now need to run to the store and get some ram which one of these are better then the g skill.
1) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3404049&body=MAIN#detailspecs
2)http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3327389&CatId=3412
3)http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3618513&CatId=3412
which of those three is the best one to get. also that ram will work in my motherboard posted earlier right?
if you need my other specs let me know. thanks.
dagger
Splendid
Mar 23, 2008
5,624
The first one. Better timing.
Although in terms of overclockablity, you'll need to do deeper research, including looking at user reviews.
hitman24
193
i was reading the first one do i need a sli motherboard because it says it looks for the sli setup? i know i didn't get a sli motherboard since i didn't want dual video cards.
dagger
Splendid
Mar 23, 2008
5,624
It'll work fine without sli, don't worry about it. But look up your motherboard model on manufacturer's website and see if that model of ram is officially supported. If not, it'll still likely to work fine. But it's better if it is.
hitman24
193
it doesn't say it this model in there. will i still be ok? i want to pick up this ram today so i need to know if it will work for sure.
