I'm gonna build a pc. will this build have no problems?
If you want to really enjoy the best gaming experience this rig will make you way happier:
http://pcpartpicker.com/p/324Lv
A $20 psu on a $1300 system? Do NOT skimp here! You don't want to fry this gorgeous setup!
Other than that, you'd still be happy with what you've picked out however, intel per core is just more powerful than amd. Most games do not use multi-core unless you are streaming. Even that's a small percentage of the market.
Get the better monitor I recommended as well. You will be looking at it everyday.
Those peripherals while I get your enthusiasm for bf4 worry about that later. Get these better parts instead so you can enjoy the actual game more and you'll have plenty of time to buy bf5's keyboard and mouse...
you always want to run in dual channel with memory and a lower cas latency is better these have a cl of 8
your hdd is a 2.5 i dont know why should be a 3.5 with rpm of 7200 costs less better performance
never skimp on psu that is a really bad power supply and could possibly destroy your componentsi added a tier 2b psu really good and reliable for 40 dollars more
PCPartPicker part list: http://pcpartpicker.com/p/324xQ
Price breakdown by merchant: http://pcpartpicker.com/p/324xQ/by_merchant/
Benchmarks: http://pcpartpicker.com/p/324xQ/benchmarks/
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($179.99 @ Amazon)
Motherboard: ASRock 990FX Extreme3 ATX AM3+/AM3 Motherboard ($104.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($74.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Amazon)
Video Card: EVGA GeForce GTX 770 2GB Video Card ($339.99 @ Amazon)
Case: Apex PCV-588 (Black) ATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: Rosewill Green 630W 80+ Certified ATX Power Supply ($59.99 @ Amazon)
Optical Drive: Asus DVD-E818AAT/BLK/B/GEN DVD/CD Drive ($18.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit) ($99.97 @ OutletPC)
Monitor: AOC E2260SWDN 60Hz 21.5" Monitor ($119.99 @ Staples)
Keyboard: Razer Battlefield 4 BlackWidow Ultimate Wired Gaming Keyboard ($119.99 @ Best Buy)
Mouse: Razer Battlefield 4 Taipan Wired Optical Mouse ($54.50 @ Amazon)
Headphones: Razer Battlefield 4 BlackShark Headset ($89.99 @ Amazon)
Total: $1363.35
(Generated by PCPartPicker 2014-03-01 04:11 EST-0500)
other than that it is fine, i will say especially with a vishera cpu if you are going to over clock you need a after market cpu cooler
and if you play mainly online multiplayer fps games i would go with this monitor which only has 1 ms of response time. it means your mouse and keyboard will be hella responsive in bf4 cod ghosts whatever your flavor is and it is only 20 dollars more
http://pcpartpicker.com/part/asus-monitor-vx228h
the 80+ designators are for energy efficiency it has nothing to do with clean power and quality of the components inside the power supply like capacitor coil and fuses that is how they are tiered and the best ones to have in a build are tier1 tier2 and tier2b
http://www.eggxpert.com/forums/thread/323050.aspx
that link is all power supplys broken down by tier
efficiency is how much power it draws from the wall socket and frankly has nothing to do with the power that is converted in your system through the coil
Those peripherals while I get your enthusiasm for bf4 worry about that later. Get these better parts instead so you can enjoy the actual game more and you'll have plenty of time to buy bf5's keyboard and mouse package in October.
And yes, I actually listed just the 1x8GB stick on purpose. Normally I too push for dual channel but as this guy is on a budget, it makes more sense to get the 1 stick now and while 8GB is sufficient atm I'm helping him prep for tiled resources coming this fall. That's new tech to use system memory over gpu ram for more detailed textures, graphics etc. We could very well see in the near future ram requirements shoot up for graphical performance:
http://www.bit-tech.net/news/gaming/2013/06/28/directx-11-2/
I know I also prefer to recommend dual channel kits but this gives him the flexibility to game now and later at top notch levels. Obviously whenever ddr4 comes into the mix that may change the whole ball game but for now this helps him play it safe either way.
And with regard to building a pc that will have no problems, no one can guarantee that. You will have problems. A driver update can cause your once stable oc to crash, hang, bsod or have artifacts and you'll have to revert the driver till the next update resolves such issues, you will have to update your pc, etc. But I get you mean will they be compatible but I assume nothing ever. In the case you were thinking absolutely 0 I just wanted to put this out there to address that. If you already knew this I appreciate your patience reading this part.
Hope this all helps! Have fun!
Thanks,
Justin S.
most of the lower watt antecs are tier 3 and there is only one evga that is above tier 3 i will agree that xfx makes some of the best power supply and bar none the cheapest higher tier quality psu however i was try to save the op some much needed dinero and using a tier2b is perfectly fine
