I'm Having Problems With Audio and Video Jitters
DanielMorosan
The power just went out 10 minutes ago and after turning my pc on I keep getting audio and video jitters. It's affecting my microphone too. I started doing a command prompt scan to see if I can find an issue but I was wondering if anyone has experienced this before or if something got messed up because of the power shortage.
Here are my pc specs
Psu: CoolerMaster CX600
CPU: Intel i7 3770k
GPU: Nvidia GeForce GTX760 (Gainward Model)
Not sure what my soundboard or motherboard are since my PC was a Lenovo prebuilt PC that I modified.
Hope someone can help. Thank you for your time
Hi,
Are you using an external speaker to play sounds or are you using an HDMI cable to play the sounds thru?
- I would suggest to uninstall/reinstall the sound driver first.
- Go to Device Manager and uninstall the sound card driver.
- Once removed reboot your PC and it should reinstall the driver automatically.
- If it doesn't install, download and install the latest driver from the manufacturer of the motherboard.
If you're using HDMI cable using the built in speaker of a TV or monitor:
- Do a clean install of the graphics card driver.
- Here's the link for the complete guide on how to do this.
- http://www.tomshardware.com/faq/id-2767677/clean-graphics-driver-install-windows.html
I am using external speakers and I tried reinstalling my audio drivers but it didn't help. I'll try my video drivers now. Thanks for the help
