So, I have the Eisberg 240L Prestige water cooler, the Cooler Master 431 Plus computer case, and the ASUS AM3 Plus Motherboard. I also have the HyperX FURY DD3 RAM. However, I don't know if the cooler will fit.
Water Cooler: http://www.coolermaster.com/cooling/cpu-liquid-cooler/eisberg-240l-prestige/
Computer Case: http://www.coolermaster.com/case/mid-tower/elite-431-plus/
Motherboard: http://www.amazon.com/Asus-M5A78L-M-USB3-ASUS-Motherboard/dp/B0054U7HIO
RAM: http://www.hyperxgaming.com/us/memory/fury
Altough I'm pretty sure that the radiator will fit, I'm not sure if the fans will fit, due to the RAM being a bit too tall.
The dimensions of everything should be in the provided links.
If it doesn't fit, is there any other way to install the water cooler? I wouldn't want to have to buy a whole new case/motherboard just for this.
If you need an image of the current setup (without the water cooler), I'll send it tomorrow, as long as someone asks for it.
