[SOLVED] I'm looking for a fan controller with a "reset" switch; please suggest of any
barkersofgeraldine
152
7
4,585
My PC case has a reset switch for the arbg lighting.
I would like to use this with my pc fans; however, the pc fans' controller doesn't have an input for the "reset" switch button to go into
i have seen other fans come with a controller with an input for the reset switch; therefore, there an aftermarket one must exist, too, right?
can someone suggest of any fan controllers they know that has a reset switch for the pc case?
Their some controllers that you can use the reset switch on the case to switch the light colors and mode. It depends on the fans you have if you can use them.
Example
