I'm looking for a graphics card. need help.
bosniankid52
21
I'm trying to setup a dual montior (Hpw1858) but i'm unable to use DVI cause I need an graphics card.
My power supply is : bestec atx 250 12z
My processor is : AMD Sempron 140
My current graphics card i believe its built in but its called Nvidia GeForce 6150SE nForce 430
Motherboard : PEGATRON CORPORATION Model – 2A99
I need an Graphics card for Dual monitors. I'm looking for a price budget around $50- 100
If anyone can help. Greatest Thanks.
You only have a 250W power supply. Most cards are going to recommend at least a 300W power supply and up, so that also a consideration. If you click on any of those video cards at newegg and then look at the details, most will list their minimum recommended power supply.
Bob
bfollett
159
30
18,740
Bob
