I'm not sure about my PC build.
Ogrich
16
Hey guys I'm a Newbie when it comes to computer building, I recently moved to live in Dubai and I wanted to buy a gaming pc but sadly everything is too expensive for me to buy here so I figured I could make my Dream pc that I always wanted with less money than what's offered in shops so here is my build please go over it tell me if anything is wrong or if I should change something. One more thing I overclock alot and I literly spend a days none stop playing games in weekends so check if this is fine with my build.
here is my build :
http://pcpartpicker.com/p/3bOLL
Get a core i5 4670k. i7's aren't any better than i5's for gaming. Use the money saved from that to get a GTX 770. You can also due with 8gb of RAM, games won't utilize 16gb for another 10 or so years. You did a good job on the power supply, but you could probably get away with something closer to 600 watts (stick with XFX though). Also, I'm pretty sure it will fit but you might want to double check the height of the Hyper 212 Evo cooler to make sure it will fit in your case.
The fan dose fit with the case but you think what i should do now is buy core i5 instead of i7 and go for 2x4 gb rams instead of 16
I want to use this pc for ateast 2 years with good performance so try be as positive about ur answers as possible and ofc a quiet pc dose this stuff im getting make noise ?🙁
I don't see any 2,5 inch slots in that case. Good to have if you plan to get an SSD, which is pretty standard in every build.
I guess you can always buy a 3,5 to 2,5 inch converter but...why not have it from the start so you don't have to waste money on a converter.
Other than that and what has already been suggested, it looks good.
Most SSD's can just be stuck to the side of the case or behind the motherboard with double sided tape.
I just build my first PC runs everygame that i play with 100FPS + with ultra resolution and 1920x1080 monitor thanks alot guys for the help specially you zeph-yr.
one more thing I tweeked some changes since I got more money I changed FANs with water cooler and core i5 to core i7 and also changed the graphic card to 780 so this baby is burning em games now :)
special thanks to you zeph_yr keep the good work up man 😀
