im not sure what case to get? help
bacon9479
69
so im going to make a custom watercooling loop and i dont know what case to get. i wanted the 900d but i want to see if i can find anything cheaper. The one main thing i want the case to have is the bottom fans. http://www.amazon.com/SilverStone-Computer-Aluminum-Unibody-TJ11-BW/dp/B004MKNNGM
http://www.amazon.com/Corsair-Obsidian-Series-Computer-CC-9011022-WW/dp/B00B1R8JT0/ref=sr_1_1?ie=UTF8&qid=1420537966&sr=8-1&keywords=corsair+900d
like those cases but not as expensive. all your suggestions are appreciated.
I think a custom loop water cooling solution is silly if the case doesn't have a window to show it off with. Do check out the Thermaltake Core v21, it's quite new so there aren't many reviews, but it looks like a great case. Also make sure you get a PSU with braided cables so it looks cool through the window, I would go Corsair for that reason.
Intel Core i7 Extreme 3960X (4.8GHz)
Asus Rampage IV Extreme
2 x Sapphire R7970 OC (1225MHz)
16GB Patriot Viper Extreme 1866MHz (4 x 4GB)
Corsair AX1200
Corsair Force 3 240GB SSD
2 x Intel 320 160GB SSD's
Hitachi Deskstar 1TB HDD
Samsung Bluray Drive
corsair 900d
then for water cooling
EK Supreme HF CPU Block
2 x EK FC7970 Full Cover GPU Blocks
EK Rampage IV Extreme Mosfet and Chipset Blocks
EK FC Bridge
Hardware Labs GTX 560mm and GTX 240mm Radiators
Alphacool VPP-655 D5 variable speed Pump
Bitspower 120mm Reservoir
Bitspower Compression Fittings
Bitspower Crystal Link
Bitspower D5 Mod Kit and Pump Top
4 x Noiseblocker Pro PK-3 140mm Fans
3 x Noiseblocker Pro PL-2 120mm Fans
Bit Fenix Recon 5-Channel Digital Fan Controller
Mayhems Pastel Grape Red Coolant
