[SOLVED] I'm pretty sure I bought an inadequate CPU-cooler so what should I replace it with ?
The_Outlander
17
I'm doing a new build. I have all of the components and I was about to start assembly when it suddenly occurred to me that my cpu cooler might be woefully inadequate for the AMD Ryzen 9 5900x that I had ordered.
It seems that I have made a pretty stupid mistake, but in my defense I may have been rushing a little bit when I chose my components. One of the things I was anxious about was choosing a cpu cooler that actually fit in my case, a corsair 4000d airflow. In my muddled thinking I chose one of the smaller options available, a Noctua NH-U9S chromax.black, which is well shorter than the 170mm maximum in my case.
I assumed that since I planned to do no overclocking the NH-U9S would be fine, but only now has it occurred to me that I was wrong. It seems that a NH-U9S can handle the 5900x at base clock speeds, but not boost clock speeds, meaning that I would have been dealing with a nightmare of consistently high temps and throttled performance. I have no choice, it seems, but to return it and order a replacement, but I figure that since I already screwed up once it can't hurt to ask before I make my decision.
I'm still settled on Noctua even though I think their marketing was slightly deceptive. The research of done suggests that even the NH-U12S might not be fully adequate so would I be ok with the NH-U12A chromax.black? All I want to do is to be able to play my cpu heavy strategy games and management sims without worrying about high temps and throttled performance.
EDIT: I might get the brown and beige version of the NH-U12A because it's $10 cheaper and I don't mind the color scheme and I guess I can add a couple extra case fans if temps still aren't ideal.
Reactions: Phaaze88
NH-D15S chromax.black would do just fine.
Compatibility list: https://ncc.noctua.at/cpus/model/AMD-Ryzen-9-5900X-1045
NH-U12A chromax.black is better than NH-U12S, but NH-D15S is above both. And based on your heavy workload, best option.
Thank you for your reply.
Somehow I missed the NH-D15S. After doing some research on it I have decided to take your advice and order it.
I admit that I am still worried about the size, even though all available information suggests it will fit.
Reactions: Aeacus
