I'm pretty sure my RAM isn't running at the correct speed.
BoxInTheJack
24
I have Team Group Elite DDR4 16Gb (2x8GB) RAM.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820313738
So if you go to the site I provided, the speed says DDR4 2400. I'm assuming thats 2400 MHz?
Anyways, I got a spec thing called speccy and it tells me this: 16.0GB Dual-Channel Unknown @ 1064MHz. Does this mean it's not running as fast as it should? If it isn't, how do I fix it? Because I'm clearly 1336 off.
Any help is appreciated, thanks :)
Ddr4 2400 will run at ~1200Mhz not 2400. It's currently ruuning at 2133 which is the default speed.
What motherboard and cpu are you using?
Did you enable XMP?
That ram is only going to run at 2133 speeds on that motherboard. The ram is DoubleDataRate so its transfer rate(advertised speed) is twice it's actual bus clock speed. So DDR 2133 has an actual bus clock of 1066(give or take a couple mhz).
In other words what you are seing is normal for your setup.
So is everything how it should be?
