[SOLVED] I'm starting a new Overclocked Build, Need some help with Parts; 2500$ Budget
Jan 16, 2019
6
I am looking at building a new PC in the range of 2000-2500$ I already have a few things bought like my case, power supply, hard drive and m.2. I really want to buy either an Intel i7 9700k or i9 9900k for CPU and an RTX 2080 or 2080 ti as my GPU. I'm tempted to water cool the whole build, But its a fairly daunting task for me.
I plan on overclocking the CPU and GPU and water cooling the CPU with a closed system water cooler. After a few months of looking around, I have created a somewhat complete part list. Parts that are not listed are things that I have already had.
Part List:
https://pcpartpicker.com/list/4hdN4q
Please check over my part list and point out any issues with the parts like performance loss or future issues. Recommendations for Parts that I could replace would also be nice.
Please keep in mind that this is only my second time building a PC and that I've only been a part of the PC community for a few years now. Thanks for any advice!
Supahos
Polypheme
Herald
Note 1) absolutely nothing wrong with your build
Note 2) this would perform better if you have any desire to play at a 4k resolution
If not disregard suggestion
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor ($308.99 @ Amazon)
CPU Cooler: NZXT - Kraken X62 Rev 2 98.17 CFM Liquid CPU Cooler ($138.59 @ OutletPC)
Thermal Compound: Thermal Grizzly - Hydronaut 3.9 g Thermal Paste ($14.29 @ Amazon)
Motherboard: MSI - X470 GAMING PRO CARBON ATX AM4 Motherboard ($183.68 @ Newegg)
Memory: G.Skill - Trident Z RGB 32 GB (2 x 16 GB) DDR4-3200 Memory ($389.99 @ Newegg)
Video Card: Asus - GeForce RTX 2080 Ti 11 GB Dual Video Card ($1269.99 @ Newegg)
Total: $2305.53
Generated by PCPartPicker 2019-01-16 12:08 EST-0500
Supahos
Polypheme
Herald
Total: $2305.53
Jan 16, 2019
6
MERGED QUESTION
Question from dylannickersonftw : "I'm starting a new Overclocked Build, Need some help with Parts; 2500$ Budget"
Part List:
You don't really need the godlike gaming mobo. A gigabyte aorus master, asrock phantom gaming 9 or Asus rog hero would do imo.
Get the kraken X72 or the coolermaster ML 360 R cooler. The 9900k runs very hot.
Go for the 2080ti with the saved cash.
Also, can you list which case and power supply you have bought?
bignastyid
MERGED QUESTION
Question from dylannickersonftw : "RTX 2080? Looking for the right card"
bignastyid
MERGED QUESTION
Question from dylannickersonftw : "Best Motherboard for rtx 2080?"
