Question Im starting to get very low FPS in csgo.
Sep 23, 2018
5
I have an i5-6600K and Ive had it for about 5 years. Late in 2018 I got an RTX 2070, which I know leads to bottlenecking but Im going to upgrade my CPU in a few months.
However, currently, while playing CSGO I'm getting fps betweem 60 and 120 usually, which hurts quite a lot for my 144hz monitor.
Got any clue what the problem might be? The only lead Ive got is that my CPU usually is between the high 50s and low 60s in temperature.
Any help is appreciated.
Look at HWMonitor, and see what temps and clock speeds....if you see it hitting all core clocks of 3.5-3.6 GHz, it is behaving normally, perhaps you've suffered a WINdows update glitch that might have replaced a needed Nvidia driver module with a default MS provided driver....
Try reinstalling all chipset drivers for mainbaord with latest, then latest Nvidia driver bundle, Express Install...(which works fine)
