I'm thinking about finally upgrading from stock! Need help!
TSoleX
22
So I finally decided to upgrade the PSU and graphics card on my HP Pavilion Slimline s5743w (http://tinyurl.com/p34pvbp).
Here are the specs from the System Information.
OS Name Microsoft Windows 7 Home Premium
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name *********-HP
System Manufacturer Hewlett-Packard
System Model s5743w
System Type x64-based PC
Processor AMD Athlon(tm) II X2 220 Processor, 2800 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 6.05, 1/18/2011
SMBIOS Version 2.6
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
Time Zone Central Daylight Time
Installed Physical Memory (RAM) 4.00 GB
Total Physical Memory 3.75 GB
Available Physical Memory 1.09 GB
Total Virtual Memory 7.50 GB
Available Virtual Memory 4.44 GB
Page File Space 3.75 GB
Page File C:\pagefile.sys
I know I'll need a more powerful PSU for a really good gfx card but I don't know where to start. Help me! =(
IMHO Building a computer from the scratch is always better than buying stock computers. You can just buy individual parts and put them together. That way you can select each part according to personal use and choice!
the case uses a very small form factor power supply called TFX power supplies. there very few units larger then 300w out there. If i was you I keep that pc as a web pc or donate it to a local library or senior center and take a donation credit on your taxes if you can. and build or buy a newer pc that uses a standard case and power supply.
with the micro case you all so have to buy the lower end low profile cards. if you had a stock case and power supply you could drop in a newer 750ti or and amd card without issue.
So would it be better to just buy a newer stock computer? I actually have a ATI Firepro HD Graphics V4800 stored atm and since it's not a low-profile gfx card, it doesn't fit in my computer plus it needs 300W. It's a workstation gfx card but I've played games on it before and it's still pretty decent.
And I'd like to spend around $150 or lower if I can just replace parts.
