Question I'm trying to fix a problem on my recently built gaming pc since it keeps crashing.
Jan 4, 2020
Specifically its the whea_uncontrollable_error and the kernal_security_check_failure. I get one or the other when starting up various programs. I believe I've narrowed the problem down to being incompatible drivers. I used the program whocrashed and got these dump directories.
On Sat 1/4/2020 7:13:47 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: pshed.dll (PSHED!PshedBugCheckSystem+0x10)
Bugcheck code: 0x124 (0x0, 0xFFFFBA0F4FBC5028, 0xB2000000, 0x30005)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\pshed.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Platform Specific Hardware Error Driver
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem.
The crash took place in a Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sat 1/4/2020 3:07:32 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\010420-8234-01.dmp
This was probably caused by the following module: hal.dll (hal+0x47FE8)
Bugcheck code: 0x124 (0x0, 0xFFFFDF84605D9028, 0xF20000C0, 0x30005)
file path: C:\Windows\system32\hal.dll
description: Hardware Abstraction Layer DLL
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sat 1/4/2020 2:48:55 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\010420-8421-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFF838E48FB7028, 0xB2000000, 0x30005)
crash dump file: C:\Windows\Minidump\010420-8281-01.dmp
On Sat 1/4/2020 5:01:14 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\010420-9625-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1C14E0)
Bugcheck code: 0x139 (0x4, 0xFFFFBD819737AFF0, 0xFFFFBD819737AF48, 0x0)
Error: KERNEL_SECURITY_CHECK_FAILURE
file path: C:\Windows\system32\ntoskrnl.exe
description: NT Kernel & System
Bug check description: The kernel has detected the corruption of a critical data structure.
On Sat 1/4/2020 4:45:13 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\010420-8203-01.dmp
This was probably caused by the following module: hardware.sys (hardware)
Bugcheck code: 0x3B (0xC0000096, 0xFFFFF8011E1EA48B, 0xFFFF8300B7486310, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: hardware.sys .
Google query: hardware.sys SYSTEM_SERVICE_EXCEPTION
Conclusion
6 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites.
Jan 4, 2020
And what is your PC? Specs please including PSU brand and model and OS.
CPU: Intel Core I9-9900KF
GPU: Gigabyte RTX 2080 Super
PSU: Corsair RM850x
Motherboard: MSI MEG Z390 ACE
OS: Microsoft Windows 10 Home 64 Bit
Memory: Corsair Vengeance RGB Pro 32GB (4x8GB) DDR4 3600
SSD: Sabrent 1TB Rocket NVMe 4.0 Gen4
Hard Drive: Seagate BarraCuda 6TB Internal Hard Drive HDD - 3.5 Inch SATA 6 Gb/s 5400 RPM 256MB Cache
CPU Cooler: NZXT Kraken X72 360mm - All-In-One RGB CPU Liquid Cooler
Case: Fractal Design Define S2 - Mid Tower Computer Case
Jan 4, 2020
Just got another crash but this time it was different than the rest.
On Sun 1/5/2020 12:44:07 AM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\010520-8171-01.dmp
Bugcheck code: 0x50 (0xFFFFE2089655FC14, 0x0, 0xFFFFF8075AFD02D5, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
This was probably caused by the following module: ntkrnlmp.exe (nt!memset+0xF056)
