Immediate Help on PSU ChoicE!!!!
viperfuzz
48
FSP Raider Edition 650W 80PLUS Silver Power Supply or Corsair HXv2 650w Gold PSU.
FSP is $60 cheaper worth the downgrade?
plz fast answer buying today!
What site is that? Do not buy the FSP, period. If I have the site I can possibly configure something to give you an alternate option for your needs. Just looking at that build, I wouldn't bother with the added cooler. You have a regular 4670 Cpu on a B85 motherboard. Heat won't be an issue for that processor. If you were to upgrade to a "k" series cpu and z87 motherboard, then you could overclock and you'd want a better cooling solution.
for a complete rig with 1x GPU (wouldnt rely on it fo sli - could get away with 650w maybe, but would feel more secure with atleast 750w minimum) 650W is more than enough for additional fans and overclocking as well.
Get the Corsair, don't compromise your computers integrity with cheap crap psus. Theres too much writen on noname brands, if the psu goes, so does the rest of your system.
Corsair are one of the highly recommended brands.
Thank you keeping it how it is Corsair HX whatever, dont want to overclock or SLI, am very bad with these things and dont feel like these is a need to for what im doing (high graphics 40fps).
And removing cooler :)
