Impossible PC -Troubleshooting Help Needed
Zack_32
Commendable
Jan 10, 2017
24
I have been having a lot of errors since i built my last PC.
It all started after about a month of use, But now has gotten so bad I cant even boot into Windows or sometimes Safe mode (Works like half the time).
- Page_fault_in_ Nonpaged_area
- IRQL_Not_Equal_or_Less
- Driver_irql_not_less_or_equal (nvlddmkm.sys)
- System_service_expection (cl.dll)
- 0x0000021a
Most of these point towards to a RAM issue, But after testing my Hyper X Fury 2x4gb with memtest86 for 48hrs straight with 0 errors, I got really confused. I can take my Video Card out the errors still persist.
My CPU [i5 6700k] is set to stock frequency, 3.8 Ghz with a H100i V2 Cooler.[Avg Idle Temp Is around 33 degrees].
I've talked to countless Microsoft support agents who knew just as much as I did. I've been told to reset my PC 4 times now and was even told to buy a new hard drive.
My Motherboard: It's a MSI Z170a 3x [https://ca.msi.com/Motherboard/Z170A-KRAIT-GAMING-3X.ht... . My motherboard is running the latest BIOS update.
My Specs: https://pcpartpicker.com/list/8TPpLD
I've tried swapping in and out the sticks of ram but I get the same with either of them plugged in. I really don't understand what could be going wrong.
I have been doing research for more then a week now so... Good Luck
If you haven't already done so, clear your CMOS and run with default settings. Next, run WhoCrashed and see if it indicates any other possibilities. If you have another PSU available, I would swap it in and see if that helps. Same thing if you can borrow another set of RAM. Failing all of those, I would consider RMA'ing the motherboard.
http://www.resplendence.com/whocrashed
