Improve or start fresh?
JoBear
Commendable
May 31, 2016
4
I've got a setup right now that I would call "middle of the road" and I want to improve it, and I'm trying to figure out the best way to go about it or if I should start fresh... Currently the setup is used for gaming and photography and not much else
Current specs:
Windows 10
12GB RAM
1TB HDD
GTX 760 2GB GPU (Zotac)
Quad i5-3350P @ 3.1
DeepCool Liquid Cooled CPU
750w Power Supply
My main concern is for gaming of course, but some extra power for editing and rendering would also be nice... What should I upgrade in your opinions?
Also I'm not against building a new rig, but please recommend a case that is good for cable management and has a ton of USB room since I use a lot of peripherals.
A new GPU would pretty much cover gaming performance. Unless you are playing some of the new CPU intensive titles, then you might push for a Xeon or i7 to gain hyperthreading and a little clock speed. Unless you have a Z77 or P68 board you won't be able to really utilize a K class CPU.
PSU is a Thermaltake (can't remember model). My budget for building a new rig is tight but doable over the course of a few months (can put in $3-400 a month towards it)... As for selling and starting fresh, I can't because I run my business off of that computer lol
Eximo what would you recommend GPU wise? The affordable solution would be to SLI another 760, but that seems almost like a waste to me... Whats the best GPU for the buck? (has to be Nvidia, Nvidia is life 😛)
That comes down to budget. To see a significant performance increase the minimum would probably be a GTX970, they are available for as low as $250 right now. The GTX1070 is about to come out though. Should be worth waiting for, but it will be in the $350+ range, and it will likely be very hard to get one on the release day.
I'm seriously considering SLI 970's... After looking at benchmarks etc they certainly seem worth their low cost and would probably measure up easily to a 980. I also run dual screens for editing so SLI seems like a logical move. Opinions?
SLI 970 is quite a bit better then a single 980, they are the same GPU class. SLI 970 even compares favorably to a 980ti. However, they are limited when it comes to higher resolutions.
970 13/16 SM Units 3.5 GB 256 bit bus 7Ghz memory 2x = 26
980 16/16 SM Units 4GB 256 bit bus 7Ghz memory
980ti 22/24 SM Units 6GB 384 bit bus 7Ghz memory
1070 15/20 SM units (larger though) 8GB 256bit bus, 8Ghz memory
1080 20/20 SM units (larger though) 8GB 256bit bus, 10Ghz memory
A single GTX1070 is going to rival a GTX980Ti and be a roughly the same price as a pair of low end 970. I would see if you could get one.
When the non-reference 1070 are out, they will be the card to have.
I'm trying to track down/ waiting for an EVGA ACX 3.0 or EVGA ACX 3.0 SC GTX1080 myself. Possibly two.
I only seem to have SLI support on my 980s with older titles. All the new game engines aren't bothering, so I may just get the single card.
