I'm currently using a Corsair 4000D airflow which is nice, but unfortunately I have an AIO that's gigantic relative to it. I have a Liquid Freezer II 280 A-RGB and it will only fit on the front, tubes up, due to my Aorus Z690 motherboard. The back hub/heatsink on the motherboard prevents it from lining up on top and the AIO radiator touches my ram anyway which messes with it, so it only fits front. The AIO fans are mounted inside, pulling air inward and I realize it's probably pulling hot air directly into my GPU. It's specifically making my 3080ti FTW 3 get a bit too hot at 80-82 c on heavy load with a fan curve that kicks in early and high. I also have the GPU undervolted to 1950 @ 925 mV. The upside is my CPU is always at very cool temperatures, but I'd like to reduce GPU temps by at last a couple of degrees and ideally be able to decrease my fan speeds if possible.
I have one 140mm fan exhaust on top, and unfortunately I can only fit 1 fan top because the AIO tubes block the rest of the space as they really can't bend any more. I have the default Corsair case fan on rear exhaust but I read they're not that great. Will adding a quality 120mm rear fan reduce my GPU temps at all? I'm open to suggestions about optimizing cooling in general.
