Question Improving my cable management.
AlexS
106
Not a bad first effort perhaps, however the two cables on the right aren't long enough to go through the top of the case and down the central column and there is no room on the other side without making a mess.
Any suggestions?
BeQuiet case and Designare motherboard.
Thanks..
my first suggestion for any who are reading, cable management is after the system is tested and the OS installed so it has a little time running. then you can futz with the cables. its a huge bummer running all the cables and having to take it all apart for troubleshooting after first boot. its a lesson you teach yourself ONCE. if already learned, you know.
invest in some reuseable (hook and loop) cable straps, zipties are great but a pain to remove and only used once.
as long as the sides go back on it looks good to me
