Recently I built a somewhat modified version of this mini-ITX build. The actual parts I ended up using are in this Google sheet, or in this gist with some installation notes. The TL;DR of the build is an air-cooled mini-ITX case with a factory clock i7 8700k and no dedicated GPU.
Prime95 stress test on Win10 using small FFTs for high heat, monitored with hwmonitor:
I was afraid the M.2 drive was creating too much heat, so to avoid having to physically remove the disks and test again, I ran the same tests from an Ubuntu live USB, using mprime monitored by lm-sensors:
I was afraid that maybe the CPU fan or case fan had failed despite hwmonitor reporting their running speeds, but peeking in the case they were definitely running.
Some other suspects I'm considering but unsure of:
If it's helpful, here's CPU info from CPU-Z. I used Noctua NT-H1 thermal paste, applied in small ~2 or 3mm circle to the middle of the processor.
Any ideas why this is happening are appreciated! Let me know if there's other troubleshooting I should try, or more info you need. I was hoping to do a modest overclock, but I'd honestly be happy at this point if I could get factory clock at max load closer to 80C.
■ ~ 30° C idle
■ 96° C max @ 1hr
■ ~ 30°C idle
■ 92°C max @ 30min
■ Should I re-seat and re-thermal-paste the CPU fan? (although idle temps were ok)
■ Should I try re-running the cables? (not much space to work with, but there's some hanging out between the case fan and CPU)
■ Could using integrated graphics be generating more heat than if I had a GPU? (although idle temps were good and CPU usage low at idle)
■ Try and jam a water cooler in? (only room for a single 120mm fan though, and the radiator would be a tight squeeze)
■ Reverse the case fan? (it pulls air in currently, positive air pressure in case, but maybe exhausting for negative temp would be better?)
■ See if I can return the tiny case and motherboard and get something with more space?
