cin19 Titan Mar 14, 2011 15,726 218 112,340 Oct 1, 2015 #2 What is your GPU and the PSU? Is your new build? or do you use it for a while? Pink display, the problem is from display, like monitor, GPU or PSU. Upvote 0 Downvote
P Praveen_5 Reputable Sep 28, 2015 3 0 4,510 Oct 1, 2015 #3 cin19 : What is your GPU and the PSU? Is your new build? or do you use it for a while? Pink display, the problem is from display, like monitor, GPU or PSU. Upvote 0 Downvote
P Praveen_5 Reputable Sep 28, 2015 3 0 4,510 Oct 1, 2015 #4 monitor works perfect its only in motherboard damn sure dude Upvote 0 Downvote
hang-the-9 Titan Mar 25, 2010 60,387 1,081 152,940 Oct 6, 2015 #5 Did you check it with another cable and test the monitor with another system? If yes, try a different video card. Upvote 0 Downvote
