In Desperate help in regards to case choice
GroovyDude97
14
I've pretty much finalized my build but I finally decided I would like to be able to see my parts ( have a windowed case). I chose the Corsair 400r Carbide prior to wanting a window and would like to know which cases are the most similar to this one that have windows.
I was told the 400r would be a great first build case and is good for the price and has great airflow. The case needs to accommodate all these parts: http://www.pccasegear.com/sc/C4Pr
Also I only want to buy the case from PCcasegear as I'm buying all my parts from there and postage is crazy expensive in Australia.
Cheers
Get a NZXT H440. If you switch the motherboard to either a red ASRock or an MSI, and changed the RAM to some red coloured RAM, your build would look great in the Red/Black H440. But if you don't mind about the wrong colours in a coloured case, stick with your original plan
