In game my GPU is at 100% load and only clocking itself at 500mhz. Is this normal, and how do i fix it if its not.
Alfalfa117
Commendable
Apr 24, 2016
In game my gpu is at 100% load and only clocking itself at 500mhz. Here are my Specs:
Intel Core i5-6600K 3.5GHz Quad-Core Processor
Noctua NH-L9i 57.5 CFM CPU Cooler
Gigabyte GA-Z170MX-Gaming 5 Micro ATX LGA1151 Motherboard
Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory
Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Sapphire Radeon R9 390 8GB Nitro Video Card
Corsair RM 650W 80+ Gold Certified Fully-Modular ATX Power Supply
I have the most up to date drivers and I am monitoring using Afterburner and CAM
I have no over clocks my temps idle are 40C load 55-60C. afterburner reading says that core clock is at 1200 mhz and memory clock is at 500mhz. It displays GPU load as spiking from 100-90 and all the way down to zero. I have performance power settings set as well.
The regular RM series has cheap components that wont last for very long on demanding high powered gaming systems like yours
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
only the RM1000x, RMi, and RM 850w versions are good
biggest red flag I see is the low quality power supply
unless it's the RMi specifically, the regular RM series are not meant for a system like yours
also if core is locked at 1200 mhz at 100% load thats good
are you sure the memory is not at 1500mhz?
run valley:
post your score and core/memory speeds while running it
https://unigine.com/products/benchmarks/valley/
I have tested in 3d mark before and i got average score for my parts. I think i solved it though. I believe it is a monitoring software issue because i downloaded GPUZ and it displayed my memory clock at 1500mhz under load during a 3D mark test. Also could you explain more one why this PSU inst for my type of build, i was under the impression that it was a fine PSU/
