Jun 12, 2021
Hi,
I am in need of 24PIN to 6 PIN atx converter for Optiplex 5080 motherboard(10500 processor 3.1 Ghz) suitable for i/p supply of 230V AC as I am planning on upgrading to 750W PSU with plan on upgrading to RTX2060/RTX3060.
Since Optiplex supports upto 360W and its really difficult to contact DELL people I decided to use corsair or cooler-master power supply which I can not fit in my case but that's okay. I will connect modular PSU from outside my case. Only problem is that 6 PIN Dell connector which powers motherboard.
There are some US based cable providers like below two links likely to work but since US 110V is standard input I am not sure if same will work.
https://www.moddiy.com/products/Dell-OptiPlex-3040-3050-3060-Main-Power-24-Pin-to-6-Pin-Adapter-Cable.html
https://www.ubuy.co.in/catalog/product/view/id/29160956/s/comeap-24-pin-to-6-pin-atx-psu-power-adapter-cable-for-dell-motherboard-with-6-pin-port-13-3-inch34cm?utm_source=gad&utm_medium=cpc&utm_campaign=inshop&loc=9062230&gclid=CjwKCAjwtpGGBhBJEiwAyRZX2p4evUlruDatufThsWuONJwl6ZyIXm5DLa095hyRRhvJ02pxLfs1kRoCrPYQAvD_BwE
Will this HP adapter cable will work for DELL optiplex 5080
https://www.indiamart.com/proddetail/cnct-0555-24-pin-to-6-pin-atx-psu-power-adapter-cable-for-hp-workstation-23106746397.html
Okay, Guys it hit to me that its about 12V o/p and not really about i/p. Fetching one from moddiy, will keep you posted about how it fairs well.
